Introduction: Applique & Embroidered Monster Quilt
This instructables was inspired because last spring my son got married and I expect a new grandchild in a few years. I wanted to make a few quilts to have a jump start and make sure all of my grandchildren have a quilt that I made. I also wanted to make it as much as I could by using the hand sewing method. I think it shows a lot more love and makes it unique. It can be machine stitched though.
Appliques are not difficult to make if you choose simple images. Close points Like the teeth were more difficult. My mother loved to applique quilts and she was very good at it. I have enough quilt blocks she made to make a couple of beautiful quilts. I cherish a quilt my grandmother made that is over 60 years old. You can see from the images that it was used often and kept family members warm on many cold nights. The pattern is Grandmother's garden, making it special because I never knew her.
I have a new kind of appreciation for hand sewn quilts, After my experience sewing this one. I over estimated how long it would take to make a small applique quilt with some embroidery work and hand sewing the appliques to the blocks. I have been working on this project for several weeks. Because my time ran out for the contest; I had to use the machine to sew the blocks together, but that is the only part of this quilt that was sewn by machine.
Follow through to see how I made it.
Step 1: Supplies
17 are Appliqued with embroidery details and 12 are plain. I had several horizontal images that I had to fit in; so I used all of them in one row at the top of the quilt. The blocks are sewn together using a 1/4" seam allowance.
Please read bottom note before cutting the applique pieces.
17 White cotton quilt blocks cut 8 1/2" X 11"
Cotton quilt scraps for appliques
12 Cotton contrasting blocks cut 8 1/2" X 11"
1 Sheet for quilt backing cut 71" X 51"
Rick rack and ribbon optional
1 Batting cut 71" X 51" I used 80/20 poly cotton
Matching sewing thread
Embroidery thread
Crochet thread for hand tying
Sewing Needles one for details and one large eyed needle for hand tying
I have never used a cotton batting before but I like the idea of natural fabrics and the cotton weighs more than the POLY-FIL so
I decided to give it a try.
Step 2: Tools
Scissors
17 Images: I did an image search for free monster images and coloring pages.
Embroidery hoop
Embroidery iron on transfer pencil
Fabric paint optional
Pen or pencil
Black marker optional
Tape measure and yardstick or straight edge
Iron and ironing board
Sewing machine or sew by hand
Seam ripper optional
Here is a link to some images:
http://www.google.com/search?q=free+monster+coloring+pages+images&hl=en&tbo=u&tbm=isch&source=univ&sa=X&ei=dUbRUMGEJ8bS2QXN5oCwCA&ved=0CDIQsAQ&biw=1536&bih=783
http://www.halloweenclipart.com/halloween_clipart_images/creepy_monster_sleeping_prior_to_scaring_people_on_halloween_night_0071-0911-1622-2725.html
Step 3: Cutting Fabric Blocks
Cotton quilt scraps for appliques please remember it is easier to cut a full size page if you will be embroidering the details.
Step 4: Cutting the Batting and Backing
Step 5: Transfer Images to the Applique Fabrics
Step 6: Embroidery
Cut out circles for eyes or other pieces that you may need; I used my printed images for the pattern pieces. Some of the pieces needed to be sewn to the design before the details could be embroidered.
For the circles I made yo yo's and pressed them and then sewed them to the design. It makes it much easier to turn the raw edges under when you sew it to the quilt block.
Embroider the desired details of the image on all the applique blocks.
Trim loose threads.
Press
Set aside until all of them are finished.
Step 7: Sewing Pattern Pieces to the Block
Pin the applique to the white quilt block centering it on the block as shown.
Hand stitch or machine stitch the applique to the quilt block.
Trim all loose threads.
Press well.
I used ribbon and rick rack for some of the areas that would make it difficult to sew.
Step 8: Painting
Step 9: Envelope Is Optional
Step 10: Sewing the Blocks Together
I found it was easier to pick up the first 2 blocks right sides together and sew them together.
Press them, and then,
Remove one block at a time putting right sides together and sew them one at a time to the first row.
Repeat this process until you have sewn 6 rows.
Then sew the rows together until your quilt top is finished.
Remove all loose threads to avoid them showing through your finished quilt.
Step 11: Layering
Place the quilt backing on the bed, carpet, or sewing table wrong side facing you.
Smooth out all the wrinkles.
Pin it down or place something heavy at the ends and sides to hold it tight.
Center the batting over the quilt backing and repeat smoothing and securing it tight.
Center the quilt top (right side up) over the batting and backing, centering it all around the edges, measuring as needed and repeat smoothing and securing. The quilt backing will be larger than the quilt top because we will be using the edge of the backing to form a 2 1/4" finished hem.
Pin all 3 layers of the hem together.
I am sorry my pictures did not turn out for this step.
You will notice the hem is doubled in the picture, I adjusted this later so please don't let that confuse you.
Step 12: Hand Tie
I hand tied the quilt using a long large eyed needle and crochet thread.
I trimmed the thread to about 1/4"after the knot was tied.
Hand tying does not take very long. I can hand tie a full-size quilt in just a few hours if the blocks are this size.
Step 13: Hem
Repeat this along all 4 edges of the quilt.
Hand sew or machine stitch the hem of the quilt.
Step 14: Cat
Step 15: Sunshiine's Final Thoughts
I would like thank our sponsors, Instructables for all the great contest that inspire us to make something fun.
Thanks for stopping by and I hope this month will bring you peace and great joy!
Sunshiiine
Sew Warm Contest
Holiday Gifts Contest
