Introduction: DIY Fibre Leaf Bowls
Do you have all kinds of fuzzy 'fibre' just waiting to become something new??? 'Or maybe some wool? These lovely bowls are made with some woolly fibre and 'pedal-to-the-metal' free-motion sewing. Don't worry, they are not very hard to make as any error really isn't noticeable. Yes, you can be 'Mother Nature' too and make some leaves...
Simple supplies:
- some Roving (wool fibre) or other fuzzy yarn (even bits of fabrics can work like I used here)
- Soluble Stabilizer (If you can't leave the house; you could use a very sheer fabric like tule or sheer curtain fabric)
- Paper, pencil & Felt tip marker
- Sewing Machine with darning or Free-motion presser foot
- Thread (clear filament or colour of your choice)
- 'Stiffy' or some other clear medium like this and a brush
- Bowl or shape
- Cling Film or plastic bag
Step 1: Pick Your Leaf Designs:
This part is so easy, you can't say that you can not draw! You can trace a leaf that you find or just look at one. Leaves are pretty easy to draw and they come in all kinds of shapes so they really can't be wrong.
Draw some leaves on paper first.
Place the Soluble Stabilizer over the drawing and trace with a felt tip marker. You do not need every vein line, just the main ones.
Step 2: Get Your Fibres Ready
The big thick pieces are called 'roving'. It is what the wool is like before it's spun into thin yarn. It is used in needle and wet felting. I had some odd colours that were variegated with lovely colours.
If you don't have roving you could improvise by using some fuzzy yarn and untwisting or a mix of any fuzzy fabrics and wool. See my scarf here to see how I used fabrics in a scarf of similar method.
Pull out some wispy bits of the fibre.
Step 3: Placement of Fibres
Place some small pieces of the fibre haphazardly across the leaf shape. Don't worry if they are over the outlines. I wanted the light to go through so I used very little fibre. Just criss-cross it so that it will give it some strength & stability.
Fold over another layer of the Soluble Stabilizer and flatten it carefully.
Pin it to keep from slipping out. TIP: If you brush a damp brush over the stabilizer it can slightly soften it enough to stick to itself, just be careful as it melts easily if too wet.
Step 4: Pedal-to-the-metal Sewing
If you like driving fast you will like this stage! Set up your sewing machine with a darning or Free-Motion presser foot (check what kind you need for your machine, as most can be adjusted for it) Test the tensions so it is not too tight.
The first sewing is just to get the background stable I used clear filament thread and also some grey thread so that it would not be so visible.
Start sewing... The free-motion foot will allow you to guide the piece in whatever manner you like. I flatten my hands on each side and start to pull it around in a random fashion. Some people use an embroidery hoop but I could not fit it under the foot. It's so much fun since you can go so fast and in all directions. It did pucker a bit but that does not matter as the stabilizer will soon be GONE!
Step 5: Even More Fun Stitching
After the main 'fill-in' sewing the darker outline stitching will be added. By that time you will be a pro at guiding it under the machine. It's also called thread painting. BUT really, it's only a leaf, no perfection needed! (you could do whatever shapes you like) I made sewn Roses in the same way, so easy!
I used black serger thread and would follow lines back and forth until it looked full enough.
Each leaf is individual and will be separate pieces until later. Make a bunch!
Step 6: Snip Snip Snip
Now that stitching has reinforced the shapes well enough, they can be cut from the Soluble Stabilizer. Be careful not to cut the edge stitching. I love all the different shapes that leaves have and pretty well any colour works too.
If you don't have stabilizer, there are some fabrics like tule that are pretty well invisible. Even some out sheer curtains could substitute, look around, use what you have.
Step 7: A Quick Dip
Soluble Stabilizer dissolves quite easily. When I use it for a scarf I wash it out completely but here you can just partially wet it so that some stabilizer remains. Then they keep their shape better and also allow shaping better. Either way will work.
Step 8: Stabilizer Gone
The fibre is even more visible now that the stabilizer is gone (or partially gone). Such lovely transparency through the wool!
At this point you can make whatever you like. Join them into a table-topper, or placemat. I like the shapes to have some sculpture so I use a bowl covered in cling film as a base form.
Shape the leaves (easier when damp/stabilizer/damp) and overlap them slightly. Leaf shapes fit into each other well.
Step 9: Make Your Bowl or Whatever
Cover as much or little of the bowl as you like with the leaves. It could be other shapes just make sure it can be pulled off after dry.
After arranging the leaves brush on some of the 'Stiffy' stiffener. It will go on whitish and then dry clear. It works quite well as I made a whole ball light fixture with it and yarn. Make sure small sections overlap to keep them together later on. If needed use pins to hold them.
It takes a long time to properly dry. If it still feels too soft add another layer of the 'Stiffy'. Twist pins to pull out.
Step 10: Move Over Mother Nature
When they are fully dry, carefully ease them off the form. They will still be slightly flexible unless you coat them many times. Fill these lovely bowls with whatever you like and enjoy!
The way the fibres mix is like marbled paint, very unique and wonderfully textured. Oh, I can imagine a few of these added to edges of a scarf... so many ideas and options! Some LED lights would enhance the lovely transparent qualities. It would make a wonderful lampshade...
I enjoy 'making' especially nature inspired projects Check my site for more 'Leafy' ideas!
THANKS for stopping by and joining in!
Grand Prize in the
Fiber Arts Contest
