Introduction: Drawknife, How to Make
Hello, in this project I show you how to make
my Drawknife.
First of all, I apologize for my lack of words, I still have to learn a lot. My mother tongue is not English and I am still learning. Thanks to all of you who are correcting me and helping me to learn. If you see any error, do not hesitate to correct me.
If you like the video please Subscribe to my Youtube Channel.
Ø How I did my Drawknife and my tools:
• Radial
• Column drill
• Belt sander
• My forge (you can see how I made it on my channel)
• Oven in my house
• Lima
• Coarse grain stone
• Grain stone 3000 and 8000
Material
• D2 steel 500 x 30 x 6 mm
Chemical composition: C (1.55) Mn (0.40) Si (0.40) Cr (12) Mo (0.75) V (0.75)
Step 1: Design:
Let´s go. The first thing I did was draw my
Drawknife, I gave the sheet 200mm with a curve of 16mm in diameter and I finished the shape making a diagonal up to 8mm from the end.
Step 2: Cut:
I made the drilling with the 16mm column drill
and then I finished the cuts with the radial. I am boring with the drill to save cutting time with the radial and discs.
Roughing:
Marking a line parallel to the edge that will be the edge of 15mm, I start roughing with my belt sander with a grain of 36 sandpaper, to take the desired shape and finish smoothing the bottom with the same sandpaper.
Step 3: Roughing:
Step 4: the Shape of the Handles:
I turn the forge and heat red hot the widest
part of the handles, with the help of a tool that I have manufactured with an angle of iron of 40 x 40 mm and some support screws where I wanted it to bend, help me with a steel bar, to pry and get the two sides equal.
In this part of the project is where I am experimenting more, due to I am not an expert in the forge, I must say that everything is done with the videos and things I can read I read.
If there is something wrong, please, do not hesitate to tell me, I would like to learn from my mistakes.
Step 5: Heat Treatment:
Normalized steel, putting it red-hot and letting cool one hour by itself.
The tempered I put it to the alive red also until it loses the polarity, that I check with a magnet and I maintain it a minute more inside the forge, cooling it with oil.
Annealing I have one hour at 200 degrees, 10 minutes for each millimeter of thickness.
Step 6: Handles:
For the Handles, I use a piece of olive tree,
with stainless steel rings. It is the first time I use the lathe, I am not very loose the subject of the rings, weighed that they would adjust when putting the tool, but it was not to I shave the handle and I have to do it again.
Then I made a 6mm hole in the part of the steel ring and finished it with a pair of hands of flaxseed oil
Step 7: Finishing and Sharpening
Review with 400 sandpaper the bottom of the
blade and the edge.
I start to get the edge with a basic Stanley stone and I finish it with a 3000 and 8000 grain stone, always using water to facilitate the sharpening
Step 8:
I place the handles with the help of a mallet
and it was ready to try it and enjoy it!
Step 9:
I hope you like it, any mistakes with the
vocabulary, please do not hesitate to tell me to improve.
Second Prize in the
Metal Contest 2017
