Introduction: How to Build a Bee Hive Stand on the Cheap
In this episode of The Bush Bee Man, Mark builds Bee hive stands with found Materials!
Things you'll need:
- 2x Treat Pine Post
- 1 Wooden Pallet
Step 1: Cut Two Break Treat Pine Post in Half.
Step 2: Cut the Pallet Down the Centre.
This will give you two tops for the stands
Step 3: Dig the First Hole.
Mark out the other holes using the pallet to measure.
Dig the three other holes.
Step 4: Place the Four Poles Into the Holes.
Fill and compact the first two holes.
Step 5: Using the Pallet Check and Adjust the Heights of the Other Two Poles Until Level.
Fill and compact the last two holes.
Step 6: Nail Each Corner to a Pole.
Step 7: Test Fit a Beehive.
Step 8: Done!
A bee stand that's built for next to nothing.
by having the beehives on a stand, it will prevent you found hurting your back.
Reclaimed Contest 2017
