Introduction: Iron Man RGB Frame
My sister is a fan of Iron Man, so I made her a custom gift: a light frame with the image of her favorite Marvel.
It is made of wood and all the cuts have been made by laser.
The light is provided by a bluetooth RGB LED strip. An application allows you to control it remotely and choose the mode (ambience, music, etc.)
Video start at 13:47 for Iron Man :
Supplies:
Step 1: Creation of the Engraving File
I made all the project in a single LightBurn file with 5 layers.
As and when I need, I activate or deactivate the layers to be cut:
- Pour l'arrière, j'active les calques vert et noir.
- Pour l'avant, le noir, le bleu et le jaune.
- Pour la tête seule, le rouge et le bleu.
Since I can't add LightBurn files in this Instructable, I am sharing a ZIP that contains the LBRN2 files, but also AI, DXF and CG if you are using other software.
I also put the font for Iron Man.
https://www.magicmanu.com/wp-content/uploads/2023/01/Iron_Man_LightBurn_MagicManu.zip
Step 2: Laser Cutting
All cuts were made with a 10W laser, at a speed of 200mm/min and at 100% power in 2 passes.
To avoid burning the wood, the boards are placed on a honeycomb grid.
Step 3: Assembly
The assembly is made with wood glue, I used dowels to re-read from front to back.
Step 4: Window
I used a scrap of plexi for the window, I cut it with a mini circular saw and I stuck an opaque window film.
This film will make it possible not to see through transparency, and will diffuse the light better.
I glued the glass behind the front face and I also kept the small pieces of the letters to add them with glue.
Step 5: Iron Man Outline
To give more relief and to have the true shape of Iron Man's head, I added the outline of his head which I glued with wood glue.
Step 6: Preparation of the Bottom
I glued a white vinyl to the bottom so that the light reflects better. Then I stuck a piece of cardboard on the dowels, it will serve as a support for the led strip.
Step 7: RGB Lighting
I glued the LED strip by making 2 turns inside, then 2 turns outside the circle.
I took care to stagger the LEDs, between the 2 towers, so that the light is more uniform.
Step 8: Wall Bracket
I have provided 2 hooks at the back to be able to fix it. But as the wood is too thin to put screws, I add a 10mm thick MDF board.
Step 9: Closing the Front Panel
I can now close the front side with wood glue.
To hide the LEDs around, I add an opaque white plastic film, then transparent semi-rigid plastic to protect the assembly. They are both glued with a glue gun.
Step 10: Table Stand
As I don't know if my sister will fix it on the wall, or put it on a piece of furniture, I also made this wooden support. It is also laser cut.
Then I screwed a cleat which has 2 screws to be able to hang the frame.
Step 11: Done!
And here it is finished! The rendering is really nice and the light is clearly visible, even in broad daylight!
Step 12: Music Mode
There is even a music mode, which modulates the light according to the music thanks to a microphone in the control box.
My sister is delighted with her gift 😉
Make it Glow Contest
