Introduction: It's Dangerous to Christmas Alone
About: I'm a geek, I'm a dad, and I make things
*quick note - I realize it's not Christmas anymore, but I neglected to finish the '12 days of Geekmas' series until now. So... sorry for the delay'
On the 12th day of Christmas my true love gave to me - a Legend of Zelda Christmas frame... because it's dangerous to Christmas alone!
Wanting to finish off the 12 Days of Geekmas with one of my favorite IP's, I made a Legend of Zelda frame, with a Christmas-y twist!
Here's how I put it together
Materials I used: (with affiliate links)
3/4 plywood board
1/4" x 1" trim
Chalkboard paint - https://amzn.to/3cZsEw7
Acrylic paint pens - https://amzn.to/2rct0fO
Minwax espresso stain - https://amzn.to/2LrLSRc
Micro Sander - https://amzn.to/2KszX46
Tools I used:
Inkscape
K40 laser cutter - https://amzn.to/2rct0fO
Vinyl weeding hook - https://amzn.to/33bUiS1
Pull saw - https://amzn.to/2TKj88f
Miter saw - https://amzn.to/2UQPZX0
Step 1: Design in Inkscape
I found some reference pictures to the classic "it's dangerous to go alone, take this!", as well as a pixelated Santa and Christmas present, and brought them into Inkscape.
For the background I used the 'trace bitmap' function to get the rocks that serve as the boarder. Using the pen tool I started tracing the trees, Santa, Link, and the present from the reference pictures I gathered, then started overlaying them on the reference picture as I completed them.
Using the text tool, I experimented with different 8bit fonts till I found one that closely matched the original font, and spelled out the holiday message.
Step 2: Pew Pew Pew
I took my 3/4" plywood board and painted it black, then covered it with some painters tape before putting it in the laser cutter (this will minimize burned edges and give a cleaner line - also helps when painting later)
I imported the design I made in Inkscape into my laser cutting program (I use K40 whisper) and set the laser to work.
Step 3: Paint
Breaking out the paint pens, I started to paint the engraved areas. I first painted the rock border, then the lettering.
Using the hook, I removed bits of the painters tape and painted as I went. Removing a portion at a time from each of the different elements helped any type of bleeding and kept the paint lines straight.
Step 4: Cut to Size
I measured a uniform area around the rock border, then cut the board to size.
Taking the 1/4" trim pieces, I measured them against the board, and then used the miter saw to cut the edges to 45 degrees.
Step 5: Glue and Stain
I took the edge pieces I cut and glued them together with the board, clamping it all together while the glue dried.
Once dry, I cleaned up the edges of the frame, and then used the stain to add color to the frame.
Step 6: Removing the Tape
To finish it off, it was just a matter of removing all the tape. The weeding hook came in handy when removing the tape from the smaller areas and around the lettering.
Step 7: Hang With Geeky Holiday Pride
With it all done, I could hang this project with geeky holiday pride, bringing joy to both Legend of Zelda fans and Christmas fans alike.
