Introduction: Lord of the Rings Lamp
I needed this in my life... that's it !
All the components available on my website : https://jeje-linge.fr/pages/lord-of-the-rings-lamp
This is pretty simple to make and everybody will stuck on this lamp.
IMPORTANT : use WHITE or TRANSPARENT PLA only.
What you need is :
- 1 Power supply 5v 2A
- 1 Arduino Nano
- 1 Connector DC2.5
- 1 Led Ring (4 parts)
- wires 20 cm
Step 1: Printing
You have to print 4 parts :
- The ring + cover
- The base + cover
I have designed several bases, choose your favorite.
Ring = > Layer : 0.1mm Infill: 0%
Base => Laker : 0.1mm Infill: 50% (minimum)
Step 2: Painting (black)
Assemble the ring and its cover then paint everything in black to make it opaque.
3 layers is generaly good enough.
Be careful: Don't make the letters opaque, paint from top and bottom of the ring, not directly the letters.
Step 3: Painting (gold)
Paint it in gold.
2 or 3 layers.
Step 4: Solder the Led Ring
Use little pieces of metal to solder the 4 parts the Led ring.
Step 5: Solder Wires
Solder wires on the 5v, GND and DN pins.
The wires should be 20 cm or more.
Step 6: Push Through the Hole
Put the Led into the ring cover and push the wires through the hole of the ring.
Then close the ring and its cover.
Step 7: Solder on the Nano Board
On the Arduino:
Solder wires on the 5v and GND pins.
Solder the data wire from the LED (DN) on the D4 pin.
Step 8: The Connector
Screw 5V and GND from Arduino et LED ring in the connector.
Be careful of the polarity:
(+) => 5V
(-) => GND
Step 9: Upload the Code
Upload the code in the Arduino.
Download the "Adafruit_NeoPixel" librarie.
Step 10: Close the Cover
Close the ring cover.
Step 11: Stare
ENJOY !
Second Prize in the
Make it Glow Contest
