Introduction: Operating the Router Table
The following outlines basic operation and etiquette when using the router table.
Step 1: Area and Machine Preparation
- Make sure there is sufficient room around the router for your workpiece.
- Press the E-stop.
- Insert a bit & table insert.
- Adjust the fence.
- Adjust the bit height.
- Clean and clear the table.
- Turn on dust collection.
- Have push blocks nearby.
- Make sure your material is clear of the bit.
Step 2: Using the Router
- Reset the E-stop.
- Turn on the router.
- Move the material past the bit in a steady motion.
- Use push blocks when handling small material or anytime your hands are near the bit.
- Keep a hand or a push block on the material at all times; never completely let go.
- If needed, turn off the router and readjust the bit height or fence to get the desired cut
Step 3: Cleanup
- Press the E-stop.
- Turn off the dust collector.
- Remove the bit.
- Brush off the table and clean up the area.
- Put scraps in the trash and reusable pieces in the storage bin in the wood shop.
Step 4: Print Out This Guide
This course is available as a PDF that is attached to this step. Happy Routing!
