Introduction: Personal Ping-Pong
Do you love Ping-Pong but hate other people?
Are you feeling anti-social but aspire to be great like Ma Long?
Do you want to train to be the best paddler but can't afford those pesky private lessons?
Then look no further than Personal Ping-Pong! Whether you are playing outside or in this summer, on vacation or at home, It's cheap, simple to make, and doesn't require anyone else!
Step 1: Parts
You will need the following:
- 8 x 16 x 3/4 inch Plywood
- 8 x 2 x 3/4 inch Plywood
- 6 x 1 inch diameter wooden dowel
- Three Screws
- Paint
- Ping-Pong ball
Step 2: Drill Hole for Handle
Find the center of the ping-pong table by marking from corner to corner. Drill and countersink a clearance hole for the screw to hold the handle in place.
Step 3: Attach Handle
Drill a pilot hole as close to the center of the dowel as possible. Using a three inch screw, attach the handle to the ping-pong table.
Step 4: Attach 'Net'
Drill and countersink two clearance holes in the center of the ping-pong table. Clamp the net in place and drill two pilot holes. Attach using screws.
Step 5: Finish Sanding
Using some wood filler, fill any imperfections in the edge of the plywood and sand smooth.
Step 6: Primer
Cover the pieces in primer to get an even coat of paint.
Step 7: Paint
Cover the handle in black, net in white, and the ping-pong table in green paint.
Step 8: Tape Off Lines
Using painters tape, cover everything other than 1/2 inch strips along the edges and down the middle.
Step 9: Paint
Cover the top in paint and once dry, remove tape.
Step 10: Assemble
Using screws, assemble the table. Go and be great!
This simple project was inspired by Personal Pong that unfortunately isn't available any longer for purchase.
Step 11: Test Step
Test Step
Outside Contest 2017
Invention Challenge 2017
Travel Contest 2017
