Introduction: Post It Notes
Here is a quick and easy way to make Post It Notes that work better than the real ones in my opinion. It is cheaper than buying them and you can use this method for any small notepad or you can make your own note pad.
You will need:
If using the two sided tape:
Thanks for stopping by and have a super special day!
Sunshiine
You will need:
1 notepad
Two sided tape, intended for hard slick surfaces.
Or:
Re-positioning glue, intended for re-positioning on paper and cardboard.
Or:
Method:
If using the re-positioning glue:
Turn the notepad over so the back side shows.
Flip over the first page and apply the glue at the top making sure you apply it evening.
You will want about a 1" strip of glue.
Store it in your desk or purse and apply it to the notepad when you need it. You just need a small tab. In my opinion this works better than Post it notes with the re-positionable glue. These notes are intended to stick longer but aren't intended to stick to paper and remove easily.
Sunshiine
Office Supplies Contest
Maker Moms Contest
