Introduction: Programing and Cutting on the ShopBot
Running an air pass will help eliminate extensive errors.
An air pass is a test cut, with the Z axis set high enough that it won’t actually cut anything. Set a false Z0, make the air pass, and if all goes well, set the real Z0 and cut the part.
Step 1: Set a Z for an Air Pass
- Jog the spindle a few inches above your material.
- This must be higher that your material thickness.
- Use an even number, like 2".
- In the KeyPad dialog, select Z- Axis only.
- Click Zero.
- Confirm in the KeyPad dialog that Z has been set to 0.
- This will set Z0 2" above your part. After the air pass, you'll enter the correct Z0.
Step 2: Load the Part File
- Click Load Part in the Position Dialog.
- Load your .sbp file.
- Confirm that the tool in the spindle is tool specified in your CAM.
- Click OK in the Position dialog
- Do not click OK yet
Step 3: Prepare for the Air Pass
- Check that the zero plate has been put away.
- Check that the ShopBot table is clear.
- Click Start in the Position Dialog.
- Do not click OK yet.
Step 4: Make the Air Pass
- Press the Reset button on the pendant.
- Press the Start button on the pendant.
- Visually confirm that the spindle is rotating.
- Click OK in the dialog box.
- This will start gantry movement.
- Stay near the computer the entire time the ShopBot is running.
- Use the space bar to pause the machine if there's a problem.
- Watch the toolpath, and observe what it's doing.
- If the cutting tool is not going where you expect it to, or if it’s dropping too far down, there’s something wrong with your CAM. See Shop Staff.
- If the air pass is successful, you're ready for the real thing.
Step 5: Make the Cut
Reset Z zero
- Open the KeyPad dialog.
- Jog the spindle down to the real Z zero.
- If you went to 2" to set Z zero for your air pass, go to -2".
- Click the Zero Axes button.
- Select Z - Axis.
- Click Zero.
Re-run the program
- Load part file.
- Start the spindle.
- Confirm it is rotating.
- Start the dust collection.
- Start the cut.
Step 6: Tool Changes
- Always remove the key when performing a tool change.
- Always make an air pass.
Step 7: Dust Collection
There are two dust collectors:
- Dust Gorilla
- It removes large chips.
- If the red light is blinking on top of the dust collector drum see Shop Staff before going further.
- The passive filter
- It filters dust from the air.
Both machines have a remote in the drawer. Press the button on each remote to start the unit.
