Introduction: Running Programs on the DMS
Remember to use the spindle dust collector when possible.
Step 1: Warm Up the Spindle
The spindle must be warmed up before use. Follow these steps if you're the first person to use the machine for the day.
There should be a small diameter tool in the spindle.
- Turn the key to Run mode.
- The door must be closed.
- Navigate to the Main Menu.
- Press Execute. (F1)
- Use the arrow keys to select the Spindle Warmup Program.
- Press Enter.
- Press Cycle Start to run the program.
- The spindle will run for about 5 minutes.
Go over the pre-run checklist while the spindle is warming up.
Step 2: Pre-Run Checklist
You're ready to run the program.
Confirm that these tasks have been completed.
- All tools have been loaded.
- Use the setup sheet.
- Confirm that the tool numbers in CAM match the numbers in the machine.
- You measured actual material size, updated the CAM program and regenerated the toolpaths.
- The tool library file is the same version that you used in the CAM program.
- All tools were measured for length.
- Work Offset (G54) has been set.
Step 3: Load the Program
Post Process your file to the thumb drive from the CAM software.
- The file must be a 6 digit number. Do not use 900000 and above.
- The file must end with .pim
- The latest post processor is in the Pier 9 Tool Library Instructable.
- Insert your thumb drive into the USB slot on the side of the machine, near the power switch.
- From the Main Menu, press Utilities. (F6)
- Press Explorer. (F7)
- This will show the available memory sources.
- Navigate to USB Disk & press Enter.
- Navigate to your program.
- Press Actions. (F3)
- Select Copy and press Enter.
- Navigate to HARD DISK/prg.
- Select Paste and press Enter.
- It's OK to overwrite an existing program.
- Press Main Menu.
Step 4: Run the Program
- Check that the probe cover is closed.
- Ensure the key is in Run mode.
- Select Hard Disk. (F1)
- Type your 6 digit program number and press Enter.
- Set the Feed Rate Override to 0.
- Keep your hand near the knob until the program is running without any problems.
- Press Cycle Start.
- Slowly increase the Feed Rate Override as the tool is descending towards the material.
- Check the "To Go" Z value on the controller when the tool is descending to prevent collisions.
- If all is well, increase to 100%.
Reduce the override after every tool change.
Step 5: Cleanup
Plan on 30 minutes to clean up.
Stop the dust collector
- Turn the key to Setup Mode.
- Go to MDI mode.
- Open the dust collection shroud.
- M66, Cycle Start
- Turn the Blast Gate switch to Off.
- Turn off the woodshop dust collector if it's not in use.
- Return the sign to the DMS controller.
Remove the tools
- Jog the spindle to the door.
- Press USER.
- Press Manual Tool Eject.
- Press Enable Tool Eject.
- Remove the tool from the spindle.
- Hold the tool to keep it from dropping.
- Press and release the green button on the spindle.
- Press EXIT twice to return to jog mode.
- Place library tools back into the drawer.
- Remove custom tools from the tool holder.
- Put away the tool and tool holder.
Repeat for all tools.
Clean the router & surrounding area
- Use a broom, dust pan & trash bag for the majority of the debris.
- Use a vacuum for the details.
- Use a vacuum labeled for the correct material.
Shut down the router
- Check that the spindle is empty & all tools are put away.
- Run the Goodnight program from the controller.
- From the Main Menu, press Execute.
- Press Memory.
- Select the Goodnight program.
- Press Enter and Cycle Start.
- Open the door.
- Throw the main power switch.
- Get your thumb drive while you're back there.
