Introduction: Scaled Leather Arm Guard
Project Summary:
Using an English Point End Punch to create a consistent scale pattern is a simple technique that works nicely for a number of shapes and sizes of projects. We’ll start by making a pattern for a basic arm guard shape. From there we’ll finish our edges, add a scale pattern and accent the scales with a camouflage and bevel tool. Red oil dye, antiquing and a top coat will finish out a very professional looking project with untold possibilities in design
Approximate Time to Complete: 2 hours each or 3 hours per pair (minus drying time)
What You Need:
· 8/9 oz. Natural Veg Tan Double Shoulder/1 sq. ft. per arm guard (11-1200DS-8/9) or (11-1202SS-8/9)
· Steel Square, 12" x 8" (65-3038)
· Measuring tape or 18” lace
· Silent Poundo Board (3461-02)
· Poly Cutting Board, 12" x 16" (65-2916)
· Tooling Slab, 12" x 12" (65800-24-12)
· 11" x 17" copy paper and a pencil
· Utility Knife (65-2860)
· #4 Heavy-Duty Scratch Awl 3-1/2" (CSO4-2)
· Rawhide Mallet (65-2520-11)
· Revolving Punch (CSO223)
· #245 Belt Punch, 1/8", (CSO245-2)
· Master Tools Edger, 1/16" (00080-2)
· Stitch Groover (8069)
· -9- Leather Slicker Exotic Wood (65-2961)
· Foam Brush (50-1952)
· Wing Divider (CSO106-10)
· Master Tools Swivel Knife, 3/8" (65-2480-3/8)
· Beveler Stamping Tool, Large, (67-6952)
· Camouflage Stamping Tool, Medium (67-6958)
· Maul, 24 oz. (65-2500-24)
· Polyhead Mallet, 9 oz. (65-2521-9)
· Master Tools English Point End Punch (00078-7/8)
· Fiebing's Professional Oil Dye, Red, 4 oz. (50-2030-RD)
· Fiebing's Antique Finish, Black, 4 oz. (50-1930-BK)
· Wool Daubers (50-1950)
· Fiebing's Leather Balm with Atom Wax, Neutral (50-2189)
· Gum Tragacanth (50-2075)
· #2200 Double Cap Rivets Nickel Plated, 1/4" (02200-NP-1/4)
· #2200 Double Cap Rivets Nickel Plated, 7/16" (02200-NP-7/16)
· Deluxe 4P Snap & Rivet Setter (65-6275)
· Latigo Lace (30-1836-DB)
· Cotton Rags
Step 1: Measure Wrist, Arm and Elbow
Begin by writing down three measurements: the circumference of your wrist, the circumference of your arm just below your elbow and the length between the two. Use a measuring tape or piece of string and a ruler to get these measurements. If it helps you to visualize the project, draw a small sketch and label it with your measurements.
Step 2: Prepare to Sketch
To prepare to sketch your pattern, fold your piece of paper in half. Smooth it out with your Utility Knife. If you drew a small sketch of your measurements, fold the piece of paper so that this space is still visible.
Step 3: Sketch in Halves
When we sketch, keep in mind that we are working in halves. Make a mark at the center of the folded edge of the paper at 5 ½ inches. Next, take your forearm length measurement we got in Step 1 and divide it in half. Make a mark at this distance below and above the 5 ½ inches mark.
Step 4: Mark Your Forearm Size
Place the long edge of your steel square at your top mark. Take the circumference of your upper forearm, which we measured in Step 1, and divide it in half. Make a new mark this distance to the left of your top mark. Make a straight line from the mark you just made to your top mark.
Step 5: Mark Your Wrist Size
Now place the long edge of your steel square at your bottom mark. Take the circumference of your wrist, which we measured in Step 1, and divide it in half. Make a new mark this distance to the left of your bottom mark. Make a straight line from the mark you just made to your bottom mark.
Step 6: Connect the Measurements
Use your Steel Square to connect the ends of the two lines you have just drawn.
Step 7: Measurement for Point
To add a point near the top of your arm guard, make a mark on your paper’s fold one inch above your widest line. Connect the end of the line to that mark with a curved line. (Note: In the second photo below, the crafter has turned the paper 180 degrees.)
Step 8: Mark Lace Holes
To prepare for your lace holes, use your Steel Square to make a parallel line ½ inch inside your diagonal line. Make a mark 1 inch inside each end of the line you just drew. Make two evenly spaced marks inside these marks so that the 4 marks are equally spaced from each other. Circle each mark. Proceed to mark the middle of each circle with your Awl.
Step 9: Cut Out Your Pattern
Use your Steel Square to cut the straight outside edges of your pattern with a Utility Knife. To cut along your curved edge, just freehand it.
Step 10: Mark Other Side With Lace Holes
Unfold your cutout. Lace holes are already punched through the side with no pencil marks. Go ahead and mark these with a pencil.
Step 11: Cut Rounded Corners
Using a Utility Knife, cut rounded corners on your cutout. For pointers on doing this, refer to Chuck’s method in the video.
Step 12: Mark Your Middle
To prepare for an oval detail that will adorn the middle of our cuff, use your Steel Square to draw a straight line along the fold that crosses with your middle mark. Extend the middle mark line so that it is perpendicular to the fold line.
Step 13: Oval Cutout
To create an oval cutout, cut out a rectangle from your scrap piece of paper, roughly 3" x 4". Use your Steel Square to create two perpendicular lines. Make a 2" long x 1" wide oval by marking each side of the long line 1 inch from the center and marking each side of the short line 1/2 inch from the center.
Step 14: Oval Cutout Step 2
Fold your rectangle along the perpendicular lines, and unfold it. Draw a curved line that connects the two marks on one fourth of your paper. Fold your rectangle into fourths again, and cut along the curved line with a Utility Knife. You now have an oval cutout.
Step 15: Trace Oval Onto Pattern
Place your oval cutout on your arm guard pattern so that both sets of perpendicular lines line up. Trace around your oval so that you now have the oval shape on your arm guard pattern.
Step 16: Trace Pattern Onto Leather
You are now ready to trace your pattern onto your leather. Place your leather on your Silent Poundo Board. Then place the pattern on your leather, and anchor it with your Steel Square (preferably with nonslip tape on the back). Carefully trace along the outside of you pattern. After this, mark your lace holes with your Awl.
Step 17: Cut Out Your Oval Pattern
To cut out your oval pattern, fold your pattern into fourths along the perpendicular lines, smoothing the fold with the bottom of your Utility Knife. Cut along the curved line of the oval.
Step 18: Mark Rivet Holes
Unfold the paper to reveal an oval-shaped hole in the middle. Mark the cutout piece for your rivet holes, making a mark a ½ inch from the center lengthwise on each side. Circle both marks and the place where the lines intersect in the middle.
Step 19: Mark Rivet Holes With Awl
Place your pattern back on your leather so that it fits in the outline drawn on your leather. Use your Awl to trace the outline of the oval onto your leather. Then, drop the oval cutout back in the pattern’s hole, and mark the rivet holes with your Awl.
Step 20: Cut Out the Leather
Using a Utility Knife, cut your leather along the outline you have sketched with your pencil. Round the corners using the Utility Knife like we did with our pattern.
Step 21: Punch Rivet Holes
Place your Poly Cutting Board on top of your Quartz Tooling Slab. Place your leather on the Poly Cutting Board, and proceed to punch your rivet holes marked in the middle of your leather using a Rawhide Mallet and Belt Punch.
Step 22: Punch Lace Holes
Set your Revolving Punch on its largest punch hole, choke out your punch as far as you can, and punch out your lace holes marked on the two sides of your leather. Punch and twist your Revolving Punch for clean holes. (Note: Refer to the video to see this in action.)
Step 23: Edge Decoration
To create an edge decoration, place the shank of your Stitch Groover along the edge of your leather. Apply slight pressure while you take it along the edges of your leather, being especially careful around the corners.
Step 24: Bevel Your Edges
Bevel your leather where the surface meets the edge. Go all the way around. Flip your leather and repeat this process for the back side. Once again, be careful around the corners.
Step 25: Wet Edges
Hold your leather above your work bench, wet a foam brush with water, and run the brush along the beveled edges of your leather. Holding your leather like this will help ensure that water only gets on the edges of your project.
Step 26: Burnish Edges
Hang one edge off the table with your hand on top of the leather. Burnish the edge with the largest groove of your Leather Slicker, remembering to get the corners too. Repeat on all sides.
Step 27: Wet Leather
To prepare for stamping, case — or wet — your leather with a foam brush.
Step 28: Scribe the Border
Set your Wing Divider to a 1-inch width, have one tip on the edge of your leather and one tip on the inside of the leather, and scribe the border.
Step 29: Trace the Border With Swivel Knife
With the help of a Steel Square, use light pressure and a Swivel Knife to trace the straight sides of the border you just scribed in. You’ll have to freehand the curved lines.
Step 30: Trace Oval in Center
Apply light pressure to your Swivel Knife and trace the oval in the center of your leather.
Step 31: Stamp Inner Border
Using a Maul and Beveler Stamping Tool, bevel the inner border of your leather all the way around. Then bevel the outside of your oval.
Step 32: Make a Scale Pattern
Begin making your scale pattern with your English Point End Punch and Maul. Only tap the Punch lightly with your Maul, as the Punch is a cutting tool and could go through your leather. Make sure the tip of your Punch is facing the flat end of your arm guard. See the photo below for general scale placement. Continue your pattern until it fills the space. You will have open areas around your inner the border that cannot fit an entire scale. We will address this later.
Step 33: Fill Edges With Punch
Use portions of your Punch to fill the edges by leaning it at angles so it won’t hit your beveled border. Use your Swivel Knife to etch in the rest of the scale on the edges.
Step 34: Bevel the Bottom Edges
Bevel the bottom edges of all your scales
Step 35: Add Camouflage Pattern
We will now add a camouflage pattern around the inside of your beveled border. To begin, place the end of the tool so that the points go on either side of the corner. Hit your Camouflage Stamping Tool with your Maul to make a mark. Do this around the entire inside border. Do this around the outside of your oval as well.
Step 36: Dry Leather
Allow your leather to dry for 3 hours.
Step 37: Add Oil Dye
In preparation for dyeing your leather, place a plastic bag on your tabletop and paper on top of that. Place your leather on top of your paper, and put on rubber gloves. Pour your Oil Dye into a plastic container. Dip your Foam Brush into your Oil Dye and brush it onto the surface of your leather. Don’t brush the edges; we will get those with a dauber next.
Step 38: Oil Dye Edges
Dip a Wool Dauber in your Oil Dye, making sure it is not too saturated — we don’t want the dye to run on the back of the leather. Pick up your leather and rub the edges with the Wool Dauber. After this, allow your project to dry for at least 3 hours.
Step 39: Add Antique Finish
Once you have allowed your project to dry for at least 3 hours, you may begin the antiquing process. Dip a new Wool Dauber into your Antique Finish and rub it onto your project one section at a time, wiping the excess off with a cotton rag as you go.
Step 40: Rub Off Excess
Once you have applied the Antique Finish and rubbed the entire surface with your cotton rag, give it one final good rub to get off all the excess dye. Allow to dry for 30-45 minutes.
Step 41: Add Top Coat
Once you have let your project dry, you are ready for your top coat. Pour your Leather Balm into a clean plastic container, and dip a clean cotton rag into it. You will want to use this Leather Balm sparingly. Rub it onto your project one section at a time, wiping the excess off with the dry side of your cotton rag as you go. Once you have covered the entire surface, buff the entire surface for a while to bring out the gloss.
Step 42: Add Rivets
It is now time to add your ¼" and 7/16" Double Cap Rivets. Place your leather upside down on your Quartz Tooling Slab and place the male ends of your Rivets in their slots. The 7/16" Rivet goes in the middle.
Step 43: Add Rivets to Opposite Side
Flip your leather over and add the female ends of your Rivets.
Step 44: Set Rivets
Set the rivets by placing the Rivet Setter on the Rivets and hitting the Rivet Setter with a Polyhead Mallet.
Step 45: Add Gum Tragacanth to Edges
Place a little Gum Tragacanth in the cap of the bottle and dip a new Wool Dauber in it. Rub the Gum Tragacanth on the edges of your arm guard.
Step 46: Burnish Edges
Burnish the edges once again with your Leather Slicker.
Step 47: Lace Holes and Completion
Use your Latigo Lace to lace your arm guard in whatever way you please. Just make sure the knots are at the elbow end of your project so that they don’t irritate your wrist. Your Stamped Scale Arm Guard is now complete!
