Introduction: Simple STEAM Project: 3D Printed Keychain
Are you looking for a fun project to introduce students to 3D printing and modeling?
I have done this activity in our makerspace with middleschoolers and with college kids. It is a simple way for learners of all ages to get started with TinkerCAD and using the MakerBot 3D Printers!
Equipment: Makerbot PLA Printer or other 3D Printer
Materials: PLA Filament, keychain rings (optional)
Step 1: Getting Started With TinkerCAD
Option 1: Individuals each create an account
- Visit https://www.tinkercad.com/ and log-in (I recommend using a Google Account for log-in)
- Select "Create a New Design"
Option 2: Instructor provides access via a Class
- Ahead of time, the instructor creates a TinkerCAD class: https://www.tinkercad.com/dashboard?type=classes
- Once the class has been created, click on its name to view and add students
- Add students by providing a name and a nickname (these can be generic, such as Student01, or specific to your roster.
- Provide the class link and the nickname to your students to use for log-in
- Benefits of this option:
- no email access needed for students to sign in
- instructor can easily view all designs created by the students
- if desired, the instructor can create a base design for the students to Tinker
Step 2: Modeling the KeyChain
- From the right drop-down menu, choose "Design Starters"
- Then, choose the sub-category "Letters and Numbers"
- Click and hold on a block letter and drag it onto the workspace
- Change the view to Top View by clicking on the cube to the left of the workspace
- Optional: I like to change the view to Flat View to turn off any perspective
- Select a new block letter and drag it to overlap with the first Block Letter
- Note: The more the letters overlap, the stronger the bond will be. Change the Snap Grid values (at the bottom right of workspace) and nudge the letter up/down or left/right using the arrow keys to get it in the right place.
- Repeat until name is complete
Step 3: (optional) Fun Shapes
- From the right drop-down menu, choose "Basic Shapes" or "Characters" or "Shape Library"
- Browse shapes and select something to add to the keychain
- Drag it into the workspace, resize, rotate and place on your keychain
- Note: since you will need to resize most shapes and rotate characters, I recommend this option for someone who is already comfortable with TinkerCAD or for more advanced students.
Step 4: (optional) Adjusting the Letter Height
The block letters are the perfect size to make small keychains. So there is no need to resize the letters. If you wish to create a sense of dimension, you can edit the height of the letters by following these steps:
- Click on the cube to the left to change the perspective to the Top/Front view
- Click on a letter and then on the white cube in the center
- Type a "3" in place of the "4"
- Repeat other letters you wish to alter
Step 5: Adding the Keychain Ring
Use an "O" for the Keychain Ring.
- Drag an "O" into the proper location.
- Change the pespective to be able to easily view the "O"
- Clicl on the letter, and then subsequently on the white sizing cubes. Change the dimensions by clicking on and retyping the numbers.
- Resize it to "3" x "3" in width and length; and "2" in height.
- Note: The default dimensions for TinkerCAD are mm. So we are making a 3mm x 3mm circle with a hole that is approximately 1mm in diameter.
Step 6: Export STL File
- Type "Ctl + A" or drag and click with the mouse to select all the shapes in your workspace
- Type "Ctl + G" or click on the Group icon to group all the shapes into a single one
- Note: The color will change; colors do not export with STL files
- Click on the "Export" button
- Choose to export an "STL" for 3D Print
Step 7: Prepare File for 3D Printing
Do this step for your students, or guide them through the process themselves!
- If you have a Makerbot printer, visit https://cloudprint.makerbot.com/ to prepare your print.
- Note: use another program for other 3D printers
- Log in at the prompt (I recommend using the Google Log-In)
- Click "Print Preparation" at the top right corner
- Click on "Add Models", then choose "Add File"
- Browse for the STL file you exported from TinkerCAD
Step 8: 3D Print Settings
- Select the Makerbot printer
- Select the correct extruder
- Select the desired base layer:
- Base layers are required for printers without heated beds:
- The default "Raft" will create a smoothe bottom surface
- "Padded Base" will print quicker and will waste less plastic, but will have a base layer with thicker extrusion lines.
- Printers with heated beds to not require any base layer
- Change the number of shells to 4 for a stronger key chain ring
- Change the infill to 0.2 for a stronger key chain in general
- Select "Export" and save the file to a USB drive
Step 9: Print Your Keychain!
- Plug the USB Drive into the Makerbot
- Select to print from USB
- Choose the file you saved to the USB Drive
- Start the print!
DIY Summer Camp Contest
