Introduction: Reclaimed & Recycled "S" Shaped Cat House/Tunnel
"S" is for our cat Sarah. You'll have to read all of the way through the build album for photos of her though... I'm a tease. This is her new cat house that is lined on the inside and outside with recycled carpet and finish with a cladding of pallet wood. It took her a little while to get used to the house but she absolutely loves playing in it and, even more, she loves sleeping on it. Overall it ended up being 3' tall, 2.5' wide, and 1' deep.
Step 1: Materials & Tools Used on This Build
Materials:
- (1) sheet of 3/8" plywood
- 3/4" wood scraps
- Wood glue http://amzn.to/2kID2jI
- Carpet
- Spray adhesive http://amzn.to/2BSavB2
- Boiled linseed oil http://amzn.to/2jQvlr6
Tools:
- Tape measure http://amzn.to/2uTi2e8
- Drywall square http://amzn.to/2Cd3Uww
- Compass http://amzn.to/2moOMIb
- Combination square http://amzn.to/2kNCCFt
- Circular saw http://amzn.to/2qr6ZnM
- Jig saw http://amzn.to/2iQTfzL
- Bench top belt sander http://amzn.to/2jmRXik
- Router http://amzn.to/2yH6t8G
- Pattern router bit http://amzn.to/2vDQsQu
- Table saw http://amzn.to/2j4bvVU
- Miter saw http://amzn.to/2j614UM
- Brad nail gun http://amzn.to/2pJiKFh
- Staple gun http://amzn.to/2zfp27y
- Air compressor http://amzn.to/2H3fNbY
- Bandsaw http://amzn.to/2j4auNu
- Wood rule http://amzn.to/2gdizmg
- Random orbital sander http://amzn.to/2jrwsJC
Step 2: Sketching and Cutting the "S"
I start with a scrap piece of wood, drawing a scaled down sketch of the shape. This helped me to determine the right proportions where our cat can play in/on it while the ratios look attractive as well.
The winning shape is chosen from my sketches and I scale it up and transfer it onto a piece of plywood. I use a piece of 3/8" thick plywood for this since it is just going to be the frame and will have another skin of finished wood attached onto it. I use my squares to draw all of the straight lines and a string with a pencil on the end as a quick and dirty compass for the larger curves.
With one of the S's draw out, I use my circular saw to cut out all of the straight lines and my jig saw to cut the curves.
I sand the edges smooth with my belt sander and then use the first "S" as a template for another one. They are temporarily tacked together with some brad nails and a pattern bit is used in the router to cut the 2nd "S" to shape
Step 3: Installing the Structure
The two S's are first held apart along the straight edges of them. I cut pieces at 12" wide and the length of the straight edges and then cut dados in them so they fit over the edge of the other plywood. You can just see the groove at the bottom of the panel here, it has a little bit of overhang for the carpet that you will see later. These are attached in place with blue and brad nails.
Now to go around the curves, I just get some pieces of scrap pine that are about 2" wide and install those in place with glue and staples in the end. I want to install carpet on the interior still, so I leave off a few of these pieces on the back side to allow me to still access the inside.
Step 4: Installing the Carpet
The inside carpet layer goes on first. I have an old stained carpet that the cats will love, so I first cut it down to the correct width and then spray the back of it and the support pieces inside the S with spray adhesive. Once that is tacky, I can put the carpet in place and I tack it along the edges with brads to help hold it in place.
With the carpet all laid down on the inside, I install the rest of the pieces of of wood in place and then proceed to the exterior surface of the S. I do the same with the carpet on the outside (this is all done in ~4' strips). This time though, I cut the width of the carpet so it overhangs each side by an inch so I can roll it over later.
Step 5: Installing the Pallet Slat Cladding
The installation of the pallet wood paneling comes next! (my cat love pallet wood). Each of the pieces has to be custom marked and cut to around the profile, but I hold the pieces at a 45 degree angle and start at one end. The extra carpet on the edges is doubled over and tucked in on the ends with each piece that I install. They pallet slats are simply installed with glue and brad nails.
Then it's just a matter of working my way around the S shape with the pallet slats. This includes: marking the pieces, cutting them to size, applying glue and rolling the carpet edge over, rolling the carpet edge over after it pops up, carpet why aren't you cooperating?!, and then brad nailing the pieces in place. And then I do the same thing on the back side...
Step 6: Cutting and Sanding the Holes
Now to get the kitty access to the inside of the S, I mark out a circle at each level with my compass and then cut them out with a jig saw.
I cut 2 holes out at first, but decided to cut one out of the center later as well. The outside surface is all sanded smooth and the corners of all of the openings are rounded over to take away all of the sharp edges.
Step 7: Finishing
For finish, I apply linseed oil to the outside of the front and back to darken and protect the wood. Once the finish dries I can bring it up into the house so the kitty can likely sniff it once and never look at it again.
Step 8: Glamour Shots
Surprisingly enough this is actually one of her favorite things ever! She loves running and jumping into the holes and then sliding between the layers while she sticks her paws out of the holes. She also loves sleeping on top of it, but now that I think of it, that's mostly what she does.
Thanks for checking out the build, but check out the build video too for the full experience:
Thirsty for more? You can also find me in other places on the interwebs!
My Website: Essentially my entire life
YouTube: Me, in moving picture form
https://www.youtube.com/jackmanworks
Instagram: Preview my projects as they progress #nofilter
https://www.instagram.com/jackman_works
Twitter: Riveting thoughts, in very small doses
https://www.twitter.com/jackmanworks
Note: This post contains affiliate links. Thank you for supporting what I do!
Epilog Challenge 9
