Introduction: Wooden Christmas Ornament
About: I run FixThisBuildThat.com where we focus on Woodworking and DIY Projects, Plans and Tools. Come check us out and let us inspire you to build something awesome!
In this Instructable I'll show you how to make a wooden Christmas ornament on the wood lathe. This is part of a 6 Days of Beginner Woodturning series I'm launching. I'll have 5 more videos all showing some easy projects you can make on the lathe that make great gifts.
Be sure to watch the video above, and if you like it please subscribe to my YouTube channel!
You can see the full 6 Days of Beginner Woodturning series here: 6 Days of Beginner Woodturning Playlist
Step 1: Gather Tools and Materials
Step 2: Rough Out the Wooden Blank on the Lathe
I'll be making this Christmas ornament on my wood lathe and I started with a nicely figured claro walnut wood blank. It's basically just a wooden brick.
The first task is to turn it from a four sided blank into a cylindrical blank. I did this by mounting the blank on my lathe in between a drive spur and a live center. Then used a square carbide cutter to knock off the corners and make it round.
Step 3: Shape the Body
Next I changed out the spur drive for a midi chuck and mounted the cylindrical blank in it.
From there I started shaping the body of the ornament with a combination of round and detailed tools. This is the fun part!
I just took away wood until it started looking good to my eye. The beauty is you can do any shape you want here.
Step 4: Shape the Ends
With the body defined I moved on to the ends.
I used the round tool to put a little stepped cone on the bottom of the ornament. But I left enough on the end to keep support on the piece with the tailstock.
On the top of the ornament I narrowed down blank and put a few details up there. Then I made a small stem that I'll later use to attach a ribbon to for hanging it.
Step 5: Finish Off the Ends
After defining the shape I sanded the entire ornament from 150 to 600 grit. I left the end of the ornament intact for full support.
When it was all sanded I came back and trimmed off the end with the detail tool then sanded the end up to 600 grit just like the rest.
Step 6: Apply Finish and Remove
I applied 5 coats of woodturner's finish to the piece. I sanded in between each coat with micromesh sanding pads using the 2400 and 3200 mesh pads.
After the finish was done I used my parting tool to cut off the stem and free the ornament.
Step 7: Drill the Hole in the Stem
I used my drill press to drill a hole in the stem with a small drill bit.
A backer board is key here to help minimize any blow out when the drill bit comes out the back of the stem.
Step 8: Hang the Ornament and Enjoy
I put a 1/4" ribbon through the hole and hung the ornament on the tree and it looks awesome!
If you want to see more of these beginner woodturning projects you can check out my playlist:
6 Days of Beginner Woodturning Projects
You can also follow along by Subscribing to my YouTube channel.
Hope you enjoyed it!
Brad
Homemade Gifts Contest 2017
