Introduction: Collapsible Whelping Crate
I made this whelping box for a breeder friend.
It is easily foldable and without tools to be stored when not in use. It is made of 18 mm thick white melamine, has a removable door and 3 anti-crush bars.
Dimensions:
- height: 45 cms
- length: 100 cms
- width: 70 cms
Material:
- 18 mm thick white melamine
- Wooden curtain bars
- M8 x 40mm knurled screw
- Locking latch
- M8 x 15mm insert nuts
Step 1: 3D Plans With Fusion 360
I drew the plans with Fusion 360, and for the first time, I used the software's animation mode, it's really nice to see what it will look like before creating it.
I put the plan to download in PDF format, the dimensions are in millimeters.
Step 2: Cutting Boards
I used 18mm thick melamine boards which I cut with the circular rail saw.
For long lengths, I used the table saw.
Step 3: Bottom Assembly
The bottom is 70 cms wide, as the boards are not big enough, I used 2 of 35 cms that I glued.
I assembled the 2 boards with wood glue and strips.
I mark an identical location on the 2 sides, I hollow out the location with the plate joiner, then I drive in the slats with a mallet and I assemble the 2 boards. I ensure a tightening with clamps I time for the glue to dry.
Step 4: Feet and Reinforcements
To strengthen the assembly of the bottom, I added 3 cleats which are screwed below. They also serve as feet for the crate.
Step 5: Small Sides
I continue with the cutting of the sides.
The front will receive a small door, I cut it with a jigsaw.
Step 6: Hinges
I used piano hinges. I cut them with a hacksaw and screw them in with small 16mm screws.
Step 7: Large Sides
To be able to fold the long sides, the hinges must be higher than for the short sides.
There is therefore a fixed part which receives the hinge for the mobile part.
Step 8: Melamine Edging Tape
Everywhere there was a cut, I stick a edging tape.
This edging tape is hot-glued with an iron. I add baking paper between the tape and the iron to avoid damaging it.
Then I cut the excess with a cutter
Step 9: Fixings
To keep the box open without the need for tools, I used locks toggle catch.
There are 4, screwed into the melamine.
Step 10: Finishing Profile
I used aluminum finishing profiles that I cut and glued over the entire upper part of the crate.
Step 11: Anti-crush Bars
For the anti-crush bars I used wooden curtain rods. I added screw-in inserts to the ends, and they are attached to the bass box with knurled screws.
Step 12: Gallows
With melamine scraps, I created a gallows that will be used to attach a heat lamp.
It is also secured with knurled screws.
Step 13: Assembly of the Crate
The assembly is easy, we start by raising the 2 small sides, then the 2 large ones, we lock the latches, we install the anti-crush bars, and finally the gallows.
Step 14: Enjoy!
Mom and baby dogs are comfortably and securely settled right after birth!
Second Prize in the
Pets Challenge
