Introduction: Creating a Molds From Aluminum Foil for Casting Lead or Tin
Hello, everyone! I've been contemplating for a long time on how to create the perfect mold for casting lead. However, making the perfect metal sphere with a reusable mold proved to be quite challenging for me. After numerous unsuccessful experiments and much pondering, I came up with a brilliant idea. While my idea is not yet perfect, the process itself and the result I achieved surprised me! So, let's get started! I hope you'll have even better success, as in future projects, I plan to refine this manufacturing process and cast more intricate metal forms!
- To create the mold, we will need the following materials:
- The object we want to replicate, preferably made of hard metal or any other material capable of withstanding impact loads (we will use a 7 mm metal ball bearing).
- Drill of the same diameter as the steel ball, 7 mm (even 6.5 mm can be used).
- Bimetallic crown or a piece of steel pipe.
- Bolt or dowel that fits snugly into the pipe.
- Thin aluminum food foil.
- A piece of plywood at least 50 mm thick.
- Grinding stone attachment for a power drill.
Step 1:
We drill a hole with a depth of 3 mm, carefully smooth out any burrs, then gently place the metal ball into the hole and delicately tap it with a hammer, sinking it approximately 1 mm.
As a result, our ball should appear as if it's half made of plywood.
