Introduction: DIY Desk Cleaner
A desk will eventually get dirty with time. It is very inconvenient to take all the bits by hand for disposal. To solve this issue, I built a Desk Cleaner by using a brushless motor. This is a very simple project requiring no microcontrollers. So, here is what you need...
Stuff you need (links are for not the ones I used): -
Step 1: The Box
For the box, I am using an old plastic container. To close it (while leaving space for the motor) I took some cardboard and made it to perfectly fit inside the case. I also kept a cloth layer on one side of the cardboard to absorb the dust but this is completely optional.
Step 2: Circuit
This is the circuit for the motor. I will be making two circuits for this project, one for the motor and one for the battery. I will be connecting both using a USB type-A cable.
I am using a small 3.7v Lithium-ion battery for this project. I am also using a power bank module which is used for charging in this project. There are 3 USB ports in the module which gives a 5V output. I will be connecting the motor circuit to one of them.
Now, connect the battery to the positive and negative terminals of the module.
Step 3: Assembly
I had some space to the side opposite to the space left for the fan. Here, I kept the battery and on top of that, the power bank module was placed. Then I connected the motor to the case using superglue. The switch was attached to the side of the case using some adhesive and insulation tape.
Connect the USB to any 1 of the 3 ports. This will close the circuit.
Step 4: Demo
So, as you can see the machine is working as expected. It can be useful for collecting pencil shavings and bits of paper.
Good luck building!
Anything Goes Contest
