Introduction: DIY Wax Foundry
About:
The aluminium drink can is one of the most commonly consumed products in the world. This project's intent is to combine a used drink can and re-purpose it into a cheap diy wax foundry for intention of recycling wax materials with the help of a 3D printer.
WARNING: As this project involves heat sources and sharp objects, adult supervision is advised.
Requirements:
- 1 250ml can or 1 355ml soda can.
- Cutting tool such as scissors or a Exacto knife.
- Pliers (Optional).
- Small heat source such as a lit candle, fluid lighter, or a heat gun.
- 3D Printer.
- * 3D Printing Filament (ABS).
- * Wax material such as candle wax or crayons .
- Casting Mold (3d Printed or Purchased).
- Mold release agent such as cooking spray or Vaseline.
*Important Notes
- Crayons have a melting point between 48C (120F) - 64C (147F)
- Most candle wax have a melting point around 37C (99F)
- Use small heat sources such as a candle or a cigarette lighter. Heat source does not need to exceed 66C(150F). Anything hotter can melt the the 3d printed handle and both 3d printed materials and wax materials are flammable.
- As 3d printed elements will come into contact with heat, it is highly advised to 3d print elements in ABS or other materials with a high glass transition temperature. ABS can become rubbery at 104C(220F) and begins melting around 220C(428F) - 250C(482F) depending on the brand.
Step 1: Download 3D Print Files
Starter 3d print files are available on the myminifactory.com platform for free download. Visit: https://www.myminifactory.com/object/diy-upcycle-wax-foundry-55330 to get started.
Additional 3d printable mold files can be found online on other platforms such as thingiverse.com, cults3d.com, and pinshape.com in addition to myminifactory.com.
Step 2: 3D Print Handle
Starter files include a handle for a 250ml can and a handle for a 355ml can. As handles will surround the can and the can will come into contact with heat it is highly advisable to print files in a high temperature filament such as ABS to avoid having the 3d printed material becoming soft and potentially melting due to heat retention of the aluminum can.
Print Settings
Layer Height: 0.3 mm
Fill: 15%
Fill Pattern: Rectilinear or Honeycomb
Supports: No
Raft: Optional
Step 3: Attaching the Can to the Handle
- Mark 25.4 mm (1 inch) from the top.
- Cut with scissors.
- Mark 50.8 mm (2 inches) from bottom of the can.
- Mark off at least thee 19 mm (0.75 inch) tabs around can and at least one 31 mm (1.2 inch) tab.
- Cut markings. Cut out 31 mm tab completely.
- Insert can through bottom of handle until the 2 inch mark made previously.
- Fold tabs over handle ring. Use pliers to bend tabs into a more secure position.
- Trim access tab material.
Step 4: Prep the Spout.
- Cut up wax into small pieces and add a little to the can.
- Hold can over heat source to melt.
- Once melted pour the wax out slowly onto a a piece of cardboard, wax paper, or something disposable.This will help guide future melted wax and help prevent spills.
- Wipe of any access spillage around outside of can.
Step 5: 3D Print a Mold
Print Settings
2 Heart Mold:
Layer Height: 0.2mm
Fill: 15%
Supports: No
Raft: Optional
Large Crayon Mold:
Layer Height: 0.3mm
Fill: 15%
Supports: No
Raft: Optional
Bear Mold (Advanced):
Layer Height: 0.3mm
Fill: 20%
Supports: No
Raft: Optional
Tips & Hints
- Higher resolution prints create smoother molds and better fittings.
- Depending on your printer you may need to sand you print to create a tight fit for 2 piece molds. You don't want wax seeping though the cracks between the two pieces.
- Use rubber bands and tape to keep 2 piece and 4 piece molds together.
Purchase A Mold (Optional)
Alternatively you can purchase molds online or in retail stores.
- CrayOn 2 Double Tipped, Triangular Silicone Crayon Molds - Makes 16 Crayons (Total)
- Silicone Chocolate Molds & Candy Molds - Ankway Set of 3 Non Stick BPA Free Flexible Hearts, Stars & Shells Mini Wax Molds (15 Cups)
Zicome 8-Cavity Adorable Flower Leaf Silicone Soap Mold Cake Decoration Mold, Set of 2
Step 6: Measure Wax
Bear Mold: requires approximately 1.9 oz of wax (about 10 full crayons)
Large Crayon Mold: requires approximately 1.5 oz of wax (about 9 full crayons)
Two Heart Mold: requires approximately 0.2 oz of wax (about 1 full crayon)
Step 7: Casting
- Apply mold release agent to mold.
- Cut wax into small pieces (about 1/2 inch) and add to the can. Small amounts will melt quicker and bleed less into other colors.
- Hold can over heat source.
- Once wax is melted fully, pour into mold carefully. Let mold sit and and wax to cool for a few minutes to a hour or more depending on the mold used before removing wax casting.
Tips & Hints
- For two piece molds use rubber bands to hold the mold tightly together.
- Make sure waxes are of the same brand or they'll melt at different rates.
- Smaller bits will melt more quickly therefore have less time to run and bleed into neighboring colors.
- To speed up the cooling process, transfer molds into the freezer after the wax begins to firm up.
Design For Kids Challenge
