Introduction: Face Mask With Breathing Valve
This is a face mask with breathing valve and PM2.5 filter pocket.
-LINK to Pattern: https://www.properfitclothing.com/product-page/fa...
-LINK to Bias tape folder kit: https://amzn.to/2ynuhnw
-LINK to Bias Tape: https://goo.gl/rtMLte
-LINK to Industrial Bias Tape Attachment: https://amzn.to/2Ua3It3
-LINK to Fabric: https://amzn.to/2lNrnly
-LINK to Lining: https://amzn.to/2QkCcb8
-LINK to Breathing Valve: https://amzn.to/39ejp9v
-LINK to Breathing Valve 2: https://amzn.to/3eM2rAF
-LINK to Braided Elastic: https://amzn.to/3aVfkX9
-LINK to Ear Elastic(soft on ears): https://amzn.to/3bZuw6X
LINK to PM2.5 Filter: https://amzn.to/2Sp5FSg
-LINK to Coated Wire Tie: https://amzn.to/2wfnmvA
-LINK to Twist Ties: https://amzn.to/2V81bB8
-LINK to Elastic Cord Stopper: https://amzn.to/35qFhwQ
Step 1: Gather Supplies
-Fabric outer layer: .25 yards (cotton, or any fabric that is tightly woven)
-Fabric lining: .25 yards (non stretch soft cotton)
-Bias tape: Extra wide
-Braided Elastic 1/8in(.32cm): 24 inches
-Cord (optional)
-Breathing valve: 1
-PM2.5 filter
-Printable Pattern
Step 2: Cut Pattern
-Front main panel: Cut 1
-Front and lining bottom panel: Cut 1 outer layer fabric. Cut 1 lining fabric.
-Lining side panel: Cut 2 lining fabric
-Center lining panel: Cut 1 lining fabric
Step 3: Hem Lining
-Mark the hem lines on the lining panels and lining side panels.
-Roll over and pin edge.
-Sew at .25 inch seam allowance.
Step 4: Lining Peak
-Place the right sides together.
-Sew as close as you can to the edge.
Step 5: Attach Lining Panels
-Overlap the center lining panel with the side lining panels.
-Tack stitch where panels overlap
-Stitch as close as you can to the edge.
Step 6: Attach Lining Bottom
-Line up notch points on bottom lining and center lining panels.
-Pin bottom in to position.
Step 7: Outer Layer Point
-Place right sides together.
-Trim seam allowance.
Step 8: Attach Bottom
-Line up notches.
-Pin
-Sew with .25 inch seam allowance.
-This step is done the same way as lining.
Step 9: Place Outer Layer and Lining Together
-Place the outer layer and lining together. Make sure wrong sides are together.
-Line up bottom notches and nose point.
-Pin together.
Step 10: Bias Tape Top and Bottom Edge (Premade Bias Tape Method)
-Add bias tape to the top and bottom edge. -You can use made bias tape, make your own bias tape, or bias tape attachment. All methods work.
-Sew in the twist tie when adding the bias tape to the top edge.
-BIAS TAPE TIE BACK OPTION: Leave 10 inches at the start and end of each edge. This will give you enough bias tape to tie behind your head. NOTE: you can always trim the bias tape down if it is to long :)
-ELASTIC or CORD OPTION: Add bias tape on both edges. Do not need to go past the sides.
Step 11: Making Bias Tape
-Use bias tape making kit.
-Cut bias tape to folder size.
-Feed bias tape though folder and iron.
Step 12: Double Fold Bias Tape Attachment
-You can also use a double fold bias tape attachment to save time. This will fold the bias tape and sew it on at the same time.
Step 13: Bias Tape Tie Back Method
-If you are choosing to use the bias tape as the tie backs you are complete and can move onto the breathing valve step.
-I do recommend cleaning up the raw side edge to prevent fraying. This is best done before adding the bias tape.
Step 14: Cord Method
-Cut cord at 24 inches. This will give you enough cord to tie around the back of your head.
-Place the cord on the inside. Roll the edge over and hem down.
-Do not sew over the cord. You want the cord to side inside the hem.
Step 15: Elastic Method
-Cut 11 inches of elastic.
-Same idea as the cord method.
-Place the elastic on the inside. Roll the edge over and hem down.
-Do not sew over the elastic. You want the cord to side inside the hem.
Step 16: Tie Elastic
-Tie the elastic ends together.
-Move the knot into the hem.
Step 17: Add Elastic Stoppers
-Elastic stopper are great for adjusting the size of the elastic loop.
-Pinch the elastic together and slide it though the stopper.
Step 18: Adding Breathing Valve
-Place back of breathing valve on the inside of the mask thought the hole.
-Snap top on to secure on outer layer.
Step 19: Add Filter
-Add pm2.5 filter and you are done! :)
Step 20: Video Instructions
If you are having trouble figuring out any steps. I recommend checking out the detailed video. I go through every step :)
