Introduction: Tablesaw Tapering Jig
About: Hobbyist woodworker, working out of a 2 car garage. Lots of tutorials posted on youtube.
There is an included dimensional drawing/PDF attached for the jig size
For the current project I’m working on, mission style side tables, the bottoms of the legs need tapers on two of the faces. With two side tables, four legs per side table, 16 tapers total that will be seen and need to be accurate? It’s time to jig up.
Why MatchFit/Dovetail clamps?
Though the MatchFit clamps by Microjig are pretty pricey, there are some benefits over the alternatives, depending on the situation
vs T-track
  • A single piece of t-track isn't too expensive, but it does start to add up. While you can recoup the cost by reusing the t-track after you've disposed of a jig, it isn't something you can switch between reusable jigs easily
  • T-track isn't too expensive, but once you start adding on t-track clamps, bolts and star knobs, the prices start to add up. T-track "hold downs" are also hit and miss - almost all of them have very small throat openings, so you can't clamp large material.
vs Toggle Clamps
  • Toggle clamps are slow to adjust! If you're using a single thickness material, and a multi-use jig, toggle clamps are perhaps the best for most jig situations... but if that thickness changes? It'll be slow to adjust every time.
    There are auto-adjusting toggle clamps, but now you're talking some serious money.
  • Just like t-track, toggle clamps can't be moved from jig to jig without unscrewing, then you start stripping out holes which then reduce the clamping pressure the toggle clamp can apply!
Step 1: Prepping for Dovetails
You can cut dovetails on the router in a single pass, but it is considerably more work for the router and router bit because you have to do it in a single pass, you can’t slowly raise the bit. In order to lessen the load on the router bit, I like to do relief cuts first.
Two passes (width wise) at the table saw per channel is fast and gets enough clearance that the router bit eases through. Two kerfs with a standard kerf blade (1/8″/3.125mm) will give a nice wide channel (1/4″/6.35mm), but still be narrow enough for the router bit. The depth of cut should be a little under 3/8″ (9.5mm)
There are two channels going along the length of the sled, so cut one side, flip the board and cut the other, then adjust the fence for the second pass per channel.
For the four short channels, the same thing can be done using the crosscut sled, but I just line up the layout lines either side of the zero clearance line on the sled for my spacing.
Step 2: Routing Dovetails
The MicroJig MatchFit system needs you to use a standard ½” by 3/8” 14 degree dovetail bit. They (Microjig) do have their own bit which adds some roundovers that looks nice, but it is not required. I couldn’t justify buying it when I already have a perfectly functional bit.
I’m repeating my self but.. the dovetail slot needs to be cut in a single pass – this is why the relief cuts were done at the table saw – since you can’t raise the bit per pass, you’d end up with a dado, not a dovetail.
The same process is done for the shorter slots too, making sure to use a push block to help keep it hard up against the fence. My router table fence doesn’t have enough travel in it for the middle slots, so I ended up using the table saw fence instead. There isn’t ever parallel issues with the router table and fence because of how the cutter works.
Step 3:
For whatever reason I find myself more comfortable with sleds that use a mitre track rather than just riding up against the fence. In this case I’m using an aluminium mitre bar, though I added wooden runners as I was unimpressed by the aluminium one.
If you don’t want to use a runner, you can just run the jig up against the fence. Every time you use the jig you’ll need to use the exact same positioning to maintain the zero clearance edge. A mitre runner has the advantage in that it will always be at the exact same mark. Washers space it up above the table, and a few dabs of CA give it a good bond.
Then it can be flipped and screwed in more securely.
The runner was offset so that the first cut removes just enough material to make a zero clearance edge.
Step 4: The Stops
For the stops, I’m using a scrap of plywood – about 100x100x18mm.
Using the recent edge guide for my trim router, I routed two 1/4″ slots all the way through.
Route one groove halfway through (depth wise) on one side then flip the board to the other side. Rinse and repeat on the the other edge and that gives you two stops from one scrap.
The scrap is cut in half on the table saw, then a corner cut is made using the crosscut sled on both pieces. This corner will act as a nice square reference for the hook. It isn’t strictly required to be done at the table saw, but it is a lot easier to guarantee squareness.
Then the remainder is removed on the bandsaw to leave an L shaped bracket
Step 5: Tapering in Action
Here’s an example of the sled in use.
Mark your work piece where the taper should start and finish on the sides. The stops can then be placed around the workpiece, making it repeatable. The Matchfit hardware slides into the grooves in the jig, with the bolt going through the slot in the stop blocks. A knurled knob then secures it all. The Matchfit clamps can then hold the work piece securely, and the cut can be performed. Using the stops allows all the other tapers to be cut consistently – either the other face on a leg, or the other legs on the table.
